Hondata vs XXX
Posted: Fri Mar 26, 2010 7:00 am
by jiggacivic
okay this is what i noticed with my car i have both hondata and E**une systems for my car and hondata seems to run the engine at higher temps than E**une. i even copied the timing values from one to the other but it still seem to run higher.on a normal day if hondata is at 206f the other is at like 196f. i live in the tropics and hondata is the system i prefer but i would love to keep my temps down as much as possible, is there anything i can do to get hondata to run lower temps.
Posted: Fri Mar 26, 2010 8:38 am
You cannot copy fuel or timing values from one system to another.
You need to provide more information. Under what conditions does the car run hotter? Is the car in closed loop? What is the radiator fan doing? What timing curve are you using?
Posted: Thu Apr 15, 2010 9:14 pm
by jiggacivic
okay so i tried to dyno tune my car today and i am still having temp issues with my hondata while on the dyno teh temp went up to 206-208 when i put the other system on the car stayed at 196.i will post cal and log file tommorrow.
Posted: Fri Apr 16, 2010 4:08 am
by XPEHODATA
Maybe temperature is the same on both system. But displayed value is different.
