IAT & ECT Correction Display
VT-Doo
Post by VT-Doo »
I can't seem to see what the current IAT/ECT Corrections are which are being applied to the map within Sensors or Display.
Am I missing something or doesn't it exist? It comes in handy with the S300.
Thanks,
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
When datalogging look at the parameters. You will need to make sure that you go to Options, Settings, Display and enable the parameter table tracing.
VT-Doo
Post by VT-Doo »
I can't seem to see where the corrections are.
In the S300 I'm using it great, but even looking at the "sensors" window in KManager there is no corrections being displayed for water or air temperature.
Can you please show me where it is, or at least a picture of it within KManager?
Cheers,
Ian
Ian
Corrections cannot be seen in the sensor list. You will have to look at your corrections in parameters and see how they are set.
VT-Doo
Post by VT-Doo »
Why isn't this the same as in SManager?
Ian
Different ECU hardware and software . It is completely different and does not have these parameters in the data stream.
