Need Skunk2 Pro1 cold start help
AllMotorMatt
Post by AllMotorMatt »
I've been playing with this tune for a bit and cannot tune properly for the motor to start up on cold starts. Normally I have to hold the throttle for about a minute then it will idle out.
Setup is Ls Vtec around 10:1 with Pro 1's and 310cc injectors. (Turbo Build)
Attached is my map, any recommendations would be appreciated!
93 DA
Ls/Vtec
S300
AllMotorMatt
Anyone?
Anyone have a pro1 map they can upload?
93 DA
Ls/Vtec
S300
AllMotorMatt
Also, I have searched and viewed all previously posted maps which are no help to me. I will try to get a datalog up asap!
93 DA
Ls/Vtec
S300
TTR
Post by TTR »
This is my map from a 13:1 LS VTEC. It starts and idles from -5 F up. Where are your cams degreed in? Let me know if it helps.
AllMotorMatt
Ill check it out ant let you in, cams are degreed, not sure exactly to what spec.
Actually, the fuel trim tab has some settings I was looking for. I eill try those and let you know.
Thanks!
93 DA
Ls/Vtec
S300
allm0t0rGSR
Post by allm0t0rGSR »
TTR wrote:This is my map from a 13:1 LS VTEC. It starts and idles from -5 F up. Where are your cams degreed in? Let me know if it helps.
is your map tune?
TTR
Post by TTR »
Its an all motor tune, never tuned with a turbo, I just posted it to help any fuel trim issues........
AllMotorMatt
Ok so I got it figured out Put a new IAC on the car and changed some parameter values pertaining to start u as well.
93 DA
Ls/Vtec
S300
