O2 Sensor constant readings of 10.7
dampa
Post by dampa »
I have a 01 civic thats k20a2 swapped running hondata on a rsx-s ecu.
I am constantly reading a A/F of 10.7 on Hondata. Ive replaced the O2 sensor, which did not fix the problem. I also replaced my wiring today with a Hybrid-Racing Conversion Harness and im still getting the same problem.
What else can I check?
bruny
Post by bruny »
is it showing a cel light?did you get the correct 02 sensor? the us , jdm spec sensor,
dampa
Post by dampa »
i was getting the p0134 & p1166 with my old sensor. replaced it with a Denso 234-9005 and the problem is still there but only throwing a p1166.
o2 readings are still pegged at 10.7
I checked the fuses, fuses are not blown. Wiring seems to be fine.
kb58
Post by kb58 »
When you figure this out please post here. I have the same problem, though mine's stuck at 14.7. Doesn't matter if the engine's running, doesn't matter if the sensor's plugged in - never changes.
Mid-engine K24 turbo Locost, http://www.midlana.com
When you have error codes it is best to follow the troubleshooting steps in the Helms manual.
Floppie
Post by Floppie »
FWIW both of them sound like wiring issues. 10.7 is the minimum reading - it can't read any richer than that; 14.7 is the "default" reading - if you turn the key on but don't start the motor, 14.7 is what you'll get. One might be a bad ground, while the other might be a bad input line.
sandrei
Post by sandrei »
any feedback on this? having the same issue here. Checked plugs,wiring,all ok!!! and still errrorr
mkulak
Post by mkulak »
I have the same issue with a car I was tuning but the car has no error codes. I'd love to know what the issue is...
VT-Doo
Post by VT-Doo »
What ECU have you guys got?
Ian
Morris Mini (B18C-R)
Honda Civic Type R (FD2)
Honda Civic Type R (FK2)
