Baro (PA) Sensor
Posted: Sat Mar 06, 2010 10:38 am
I notice among the recorded variables in the sensor column I cannot find the Baro (PA?) sensor. I require this for monitoring MAP performance when comparing different intakes/modifications.
The Baro sensor is my required offset for doing comparisons between base MAP pressures on different runs done on different days and locations.
It is in affect the Altimeter, however despite being able to add it in the "Define Templates" column, I want to confirm that others have seen this at values other then 0.0 and it would be helpful to see it included in the Sensor List.
I am working with some logs around 4500ft ASL and still see the PA indicating 0.0. Last tested in 1.1.4.3.
Thank you,
Steve.
Thank you,
Steve.
