I would like to output the innovate wideband sensor data to my P08J+S300J, may i know what should i do in the first step?
To what i know, in-order to make this work with my P08J+S300J,
Software Section
- I have go to the menu at the top in Smanager
- Select "Options"
- Select "Settings"
- Select tap under "Units"
- Under "Lambda Unit", select "Air Fuel Ratio" radio box.
- Click on button "OK" to close the window.
- Then go to the "Parameters"
- Select "Close Loop"
- Un-tick "Close Loop operation" when tuning
- Under "Wideband lambda", select the Wideband input source (Depend which wire/pin that we are going to use to input the wideband sensor signal)
- No required to change the Voltage offet value
- For 0.00 voltage, put value 7.35
- For 5.00 voltage, put value 22.39.
It is correct?
Hardware Section
Screen below is the innovate wires assignments, in this case, i will use pair 2 (Brown White+ and Dark Green-), i will connect the BrownWhite to the 1 of the 4pin, and the DarkGreen to any ground, my idea izzit correct?
Which pin is good to use for Hondata ECU?
to what i know, there are 4 pin availaible for analog input.
1. D10 ELD (My car is year 98 OB2A B16A using converter harness, what are required need to be done if using D10 ELD?)
2. D12 EGRL/Analog Input 1 (My ECU not a US version but a JAPAN version ECU, according to hondata, C42 must contain a 0.1uF capacitor in US version OBD1 ECU for this input to work correctly, but for my Japan ECU? what are required to be done?)
3. D4 O2 (My car is year 98 OB2A B16A using converter harness, what are required need to be done if using D10 ELD?)
4. B6 AN2/Analog Input 2 (According to hondata, R2 and R3 in US version OBD1 ECU must be removed for this input to work correctly, but for my Japan P08J ECU? what are required to be done?)
My idea is to use Pin B6, I will connect (tap or single connection??) the Innovate wideband meter wire Brown&White to ECU OBD1 Pin B6, and tap the Innovate wideband meter wire DarkGreen to OBD1 ECU PIN A26, correct me if i'm wrong.
My appreciation for any helps, thank you thank you!!!
