Kpro and inmobilizer
jdmvtec93
Post by jdmvtec93 »
i have my original ECU with kpro, i loaded a calibration and the inmobilizer dont want to work. as soon as i enable the inmobilizer the car wont start (ECU, Key and Switch are Original)
What should i do?
What is the code on the side of the ECU?
jdmvtec93
Post by jdmvtec93 »
there is no code just when i enable the immobilizer the car wont start.
one thing i did was to try to download the calibration that was on the ECU to my laptop, because before that it was working ok.
There has to be a sticker with the model number on the side of the ECU.
jdmvtec93
Post by jdmvtec93 »
Spunkster wrote:There has to be a sticker with the model number on the side of the ECU.
ok
37820-prb-a05
2068-506714
You must turn the key off and back on before starting it after enabling the immobilizer. IF it still does not work you will have to take it to a Acura dealer to have the immbilizer rematched to the ECU.
