I have a '00 civic lx(d16y7) which as a 3 wire IACV and I swapped out the ecu for a p06 which comes in a 92-95 dx/lx so that I could run hondata s100b. Now the problem is that the p06 controls a 2 wire IACV and I am running a 3 wire so my idle sucks. What is the easiest way to go about fixing this problem? Thanks,
Pfieff
OBDII hondata IACV issues, need some help/suggestions
your best bet would be to use a intake manifold off a d16z6 or d16y8. A side draft throttle body off a d16z or d16y8 auto, that has a FIT valve(cold idle valve) mounted to the bottom of the throttle body and a plunger/linear style IAC off a OBD1 civic. D16y7's use a rotary style IAC (3 wire as you said) and I'm pretty sure a plunger/linear IAC style wont bolt to your throttle body.
Rob
