P08J with S300J Queries
Posted: Fri Feb 19, 2010 11:38 am
Dear All,
My appreciation if anyone can answer my questions below:
1. Does S300J removes the speed limiter? Software supported?
2. I have one after market Spec R VTEC controller wihch can change the VTEC engage point, shift light flash and removes the speed limiter, however if i use it with Hondata? any side effect? As i know the vss wire and vtec solenoid/vtec pressure wire will have to link to the device and then go to the ecu.
3. Is it possible to create a button for map switching purpose? (example: Drag Mode, Track Mode, Street Mode and etc)
4. A bit warm on my hondata S300J P08J ECU after 2 hours driving, is it normal?
5. I've installed a Carputer with 7"inch touch screen LCD in my car, is it possible to auto open "FULL SCREEN F11" after starts the SManager? currently i have to manual press F11 twice to make it to full screen.
My car is stock EK4 auto OBD2A using selfmade converter harness to connect to OBD1 P08J S300J hondata.
Sorry for my bad english, thanks anyway..
