anybody know them for manual tranny??
thanks
rp17 rp18 resistor value on p08
It's a zero ohm resistor, i.e. - a jumper wire. You can solder in a direct connection like a small piece of wire, or if you're picky [like me] you can go to radio shack and pick up a zero ohm resistor and solder it in place.
This resistor value [of zero ohms] is the same for all Honda OBD1 ECUs, whether they are manual or automatic. The difference between manual and automatic is where the jumper is located [either in RP17 or RP18]
ooook lol,
2 resistors 2 values ; )
for P08 set up for manual...
http://www.hondaswap.com/~pills/autotomanual.html
says : "For JDM OBD1 ECUs:
RP18 (in the same location as usdm) needs to be lowered in value from 2.4k to 1.4k ohms"
now for rp17!
does it stay the same? and if so what should it be
now for rp17!
