PLX vs. AEM?
Posted: Thu Feb 11, 2010 2:46 pm
by darkstarsinner
Okay so I have already read that the PLX wideband works with the S300. Is there anything else from PLX that can be linked to the S300? I am going to be running a full set of gauges (i.e. Boost, A/F, Oil temp, EGT,) And am stuck between the PLX line and the AEM line. Right now the biggest factor is that the AEM line is actually cheaper. But I want to make dure everything is functional with my S300. Any input would be appreciated. Thank you.
Posted: Thu Feb 11, 2010 5:15 pm
YOu can use any of their modules that output a 0-5 volt analog signal that can be entered into one of the Smanager analog inputs. I personally use the AFR and EGT from PLX.
Posted: Thu Feb 11, 2010 8:58 pm
by darkstarsinner
Thank you. I thought about running those two from PLX then using the AEM for the others, but I'm to picky and really want them to match, lol. But that is great info, at least I know they will work either way. Thanks again.
