3 stage obd2 D15b basemap NEW MAP 3-26-10
Customy8
Post by Customy8 »
D15b, stock map sensor and injectors, added more timing in low end, great part throttle response and cruising, LEAN BURN MODE ON THE WAY!!! using secondary tables by cruising conditions, ie rpm-rpm, load, tps %. edited 3-26-10. All parameters are set , fuel and timing up to 12psi, not recomended with stock injectors, duty cycle exceeds 80% "the safe zone" at 7k rpms at 4psi. 12 to 16valve engages at 3k rpm in nos/auxillary, green vtec wire connected directly to the air conditioning clutch wire. vtec around 5k, this is all i can give as a base map, any more tuning for my car wont work so well for others, being mine is remote mount turbo with custom exhaust and intake. This IS A TURBO Base map, may feel sluggish on a N/A car. Lets hear from you guys! what car do you have this motor in, what mods? I have a thread on d-series.org. http://www.d-series.org/forums/engine-m ... ntrol.html i want to hear from you guys. new map is posted, any questions email Dstorm19@gmail.com
newsoltsc
Post by newsoltsc »
nice find!
-Jose
Customy8
Post by Customy8 »
I'm currently running this map on my car, with base timing @ 16, if you own a 3stage d15b, a hondata s300 is a must!
