Error CODE Description
21 VTS VTEC spool
22 VTP VTEC pressure
VTEC setup in RomEditor is:
Fixed VTEC Point @2500 RPM
Minimum load, only change cams if engine load is above 1299 mbar
The spool light comes on at 1500mbar and 4539 RPMs
The VTP error happens right after.
IAB secondary intake runner / IAB revs are 5750. Is this the secondary butterfly valves? If so, these are removed with the Supercharger install.
2000 Prelude
Engine is H22
Jackson Racing Super Charger @6PSI
ECU is P28
Any advice?
VTEC spool and pressure errors
Bitten by the boost bug
