Constant Speed Signal, gear always 6th
Posted: Tue Jan 26, 2010 10:41 am
2002 honda CRV ecu Kpro'd
Serial number - (will check when I have access, but it just got Kpro'd less than 3 months ago so very recent)
Kmanager version - 1.3.9
Engine is K20A3, using automatic transmission
Auto ECU is controlling transmission, Kpro ecu is controlling engine
Happens in ANY calibration, will use base K20a3 calibration has a reference.
No check engine lights at all, Kpro is working as intended except.....
Is there any way to set it up so when you use "constant speed signal" instead of VSS input that the ecu thinks you are in 1st gear instead of 6th? Its giving me some throttle tip in ignition retard issues
I can't use the VSS signal from the transmission because it is the high frequency type, and the auto trans is using the signal to control... the auto trans
When I set it to use the VSS signal (of which there is none) the MPH reads 0, gear 1, and the issue is gone. However, a check engine light will come on saying VSS signal error after a few miles of driving.
Is it possible to change the constant speed signal to be something other than ~50mph? Maybe 0 mph?
