acura dual harness set up
remus
Post by remus »
I have a 2004 acura tsx with dual ecu set-up.
the second ecu is a rsx type-s 6 speed 2004.
the problem i have is that the green light key flashes normaly and goes off exactly like before the dual setup.
But if I enable the imobilizer in k-pro it will not start the car, I need to disable it in order for the car to start is something wrong or that is what it is when you have a dual setup with adaptor harness.
Thanks for your time
It must be disabled. It cannot be enabled.
