Cranking Fuel Trim
Posted: Mon Jan 25, 2010 11:24 am
KPRO
2005 Honda S2000
ID1000cc Injectors
Aftermarket fuel rail with stock pulse damper
I was wondering if you could assist me with a cranking issue. With the ID1000s I have to use a cranking fuel trim of -38% in order to allow the car to start up properly. I have adjusted the voltages and dead times to match the injectors with my static fuel pressure.
I know that you state the cranking ignition values are on the low cam ignition table in columns 8,9,10 and rows 1&2. Is it also true that the fuel tables in this same table can be trimmed to allow a better startup?
2005 Honda S2000
ID1000cc Injectors
