s200 hondata for burning chip
Posted: Sat Jan 23, 2010 8:58 am
by bseriesluver
i have s200, and i have updated with the cable. i have not install s200 on the my car yet. i have not tune my car yet, but i have socket everything in my ecu p28. ok i opened the base map with romeditor 4 and i go to save as and save file as bin file then i used burn1 chip programmer and burned the basemap down. after that i use the eprom chip plug in the ecu, the car start fine but i cant rev up to 5k rpm. so will you let me know y is that, and do i have to hook the s200 blue box along with ecu or not?
note: i thought that i just burn the chip and plug and play as crome did.
thank you
Posted: Mon Jan 25, 2010 10:59 am
What is the Romeditor4 serial number?
Posted: Thu Feb 18, 2010 12:09 am
by bseriesluver
what do u mean by romeditor4 serial number?
Posted: Tue Feb 23, 2010 11:18 am
If you have not purchased Romeditor 4 then you cannot save or burn files. I would highly recommend just upgrading to the s300 if you wish to tune yourself, as it will be easier and cheaper and has more features.
http://www.hondata.com/s300upgradeform.html
