ELD voltage reading 5 volts unplugged
The Spectacle
Post by The Spectacle »
What should the ELD voltage reading be with nothing plugged in? Mine is reading 5 volts...want to make sure this is normal before I go through the trouble of volt metering my wideband output.
Thanks.
contectr
Post by contectr »
i have the same problem and i can't say how to fix it :-(
PRA ECU K20A2 european Civic Type R My2004
Honda Ep3 stock k20a2 jrsc
What wideband are you using?
on the bench with nothing connected it shows 4.55V
The Spectacle
PLX
I'm having issues with my wideband showing below 12.3 afr. Trying to narrow down the cause
contectr
Post by contectr »
yeah i read 4.55V with the ELD wire unpluged!how this??
i want to use it for connect my EGT PLX linear output but they don't work well...
The Spectacle
Spunkster wrote:What wideband are you using?
So how does this work? Reverse voltage reading or something? Do I need to start playing with voltage offsets to get my WB to read below 12.3 AFR? PLX says they're not required so something is not jiving...
voltage offset is used to match the reading from the wideband display to the datalogged value.
The Spectacle
So no.
Can you answer my question? Is the ELD voltage right?
Spunkster wrote:on the bench with nothing connected it shows 4.55V
How exactly do you have the wideband connected?
The Spectacle
0-5 volt output from the SM-AFR box connected to the ELD pin.
complete details...where have you connected it to power and ground, etc...
The Spectacle
Power is coming off a spare switched spade connector in the fuse box, ground is one of the screws used to attach the hood latch. I've tried another power source and got the same results.
