daughter board error communication
doctorpcmxl
Post by doctorpcmxl »
My car turns well without error codes, The problem is when the car makes the output torque on launch,
CEL lights on, and kills VTEC, and run without VTEC the drag race, and returns VTEC to high RPM in 3rd Gear...
when I stop accelerating protected in 4000 RPM (limp mode).
Turn off and turn on the engine and CEL is off . (normal mode)
my battery is an Odyssey, Alternator send 14.5 volts in the battery, but in the kpro read 13.2 V, an drops to 11.5 when accelerating.
I changed alternator, battery, put more grounds in the engine.
Check continuity in the socket of the alternator to the PLUG B, PIN 10 y
and PIN 18 and all is OK.
in the PIN 10 read 8V, and in the PIN 10 read 8V,
and in the PIN 18 read 11.5 V.
My battery is located in the back seat (passenger) my car is CRX 90
What could be!!
Mi carro si enciende bien sin codigos de error, el problema es cuando el carro hace torque en el arrancon.
se enciende CEL, y se elimina el VTEC, termino corriendo sin VTEC, y vuelve a altas RPM en 3rd Cambio.... cuando dejo de acelerar se protege a las 4000 RPM (limp mode).
Apago y enciendo el Carro y se apaga la CEL.
mi Bateria es una Oddysey, el alternador marca 14.5 Volts en la bateria, pero en la KPRO me marca 13.2v, y baja hasta 11.5 cuando lo acelero,
Ya cambie de alternador, de bateria, puse mas tierras en el motor.
Cheque la continuidad en el socket del alternador a la PLUG B, PIN 10 y PIN 18y todo esta OK.
en el PIN 10 me marca voltage de 8 V,
y en el PIN 18 11.5 V.
Mi bateria esta localizada destras de el asiento del pasajero,(ES UN CRX 90)
que puede ser..!!!
__________________
WWW.MYSPACE.COM/DOGMXL
[/b]
You need to measure the battery voltage at the ECU when cranking the engine over. It is probably dropping too much which is causing the problem. We do not recommend relocating the battery as this can cause voltage drops.
