I need to know at what % I need to set all the compensation tables for air and water open and close loop, high and low load. My car was tune 2 days ago but when I first start it in the morning, 22 deg. air temp it runs way too rich. I have to stay on the gas to keep it runing for about a minute. After that it runs but it stil runs in the 10 to 1 fuel ratio til it's fully warm, then it runs between 11.8 to 14.5 to 1 ratio at cruising loads. The car has a new AEM wide band meter. I also need some help with data logging, and how to save it in the computer so I can adjust the low fuel tables.
Thanks for the help, I'm new at this.
need values for the fuel compensation tables, water and air
2001 Turbo GSR, BB SC61, 1000cc injectors, stock block w/block guard, arias pistons, eagle rods, p28 w/s300, LSD, Type S BOV, Tial 38mm w/g, blox manifold, 3" down pipe, Thermal 3", Zex turbo cams, AEM gears, MSD 6BTM
I'm running 18 PSI. What are you running? I'm trying to do the lite loud tunning myseft, but I'm new with this Hondata stuff and I can't even get the base maps to read real time. I have a Camaro with an ACCEL DFI and it is a lot easier to use. :?
