Hi, have a hondata s300 installed in a p28 ODI. I recently installed the PWM component to control the boost with s300. And then when i try to access to high speed table it kind of enter and get back to the preveious table i was, so i cant access to the high speed table. When i insatall the s300 the ecu had chip already and i checked all the steps for the installation of the s300 and they are right, exep for the c14 that we didnt replace because the guy who istall it told that already was it, so we didnt replace it. But before i take the ecu to install the pwm component it was fine.
Hope someone can help me fix this problem.
Civic 97, B18b
conversion ODII to OBDI
gt25r, 8spi
Cant acces to high speed table
fly_n to the rescue, again...fly_n wrote:hit options at top of page & uncheck the "Tables Follow VTEC" checkbox.
Very common question, yes. Two code change thoughts:
1.) Uncheck, by default, "Tables Follow VTEC" in smanager. (then of course people will ask "why won't it follow high speed cam?)
2.) Perhaps it should only follow/flip to high speed table when the transition to vtec is made, allowing the application to transition to the vtec table semi-automatically and not forcing the view back to low speed cam when using low speed cam.
I bet, however, that the easier solution is to RTFM. :!:
http://www.urbandictionary.com/define.php?term=RTFM
Just trying to be funny, not rude.
Mike
