Need asap a good map for n/a set up...
allm0t0rGSR
Post by allm0t0rGSR »
Block B18c1 cr:11.5
forged je piston size 82mm
forged eagle rods 87mm (ls)
forged je crank 89mm
Head b18c1
crown dual valve spring
3 angle valve job
plug NGK BKRE7's
type r cams
blox intake manifold
440cc
replica itr headers
need map asap and what is the good spark plug gap setting for high compression engine
