P28 no power
Posted: Sun Jan 03, 2010 9:29 pm
by Poey2
Hi,
My s300 p28 ecu just died last night for no reason. It started with occasional power then no power. When I said no power there is no light and no connection to the labtop. Then it would power up after several seconds. Now its not working at all.
Is it the s300 or a bad ecu?
thanks
Posted: Mon Jan 04, 2010 1:34 pm
More than likely it is the ECU. Have you chekced inside the case? Does it smell funny?
Posted: Wed Jan 06, 2010 6:55 pm
by Poey2
the ecu smells fishy... ??
I have a P75 ecu that i would like to use. Can i transfer the S300 to the P75 and still have Hondata control vtec?
Posted: Thu Jan 07, 2010 10:22 am
The fishy smell is the main capacitor that has died. You may be able to replace it, but usually it damages the circuit board. IF you use the P75 you will have to use a relay and use the alternate VTEC output.
Posted: Thu Jan 07, 2010 7:02 pm
by Poey2
thanks for answering my questions
I have found this vtec conversion online that i would like to experiment with.
http://www.xenocron.com/vtec-conversion ... ecfd29f4e9
If i use this kit will i still need to use a relay and an alternate vtec output on my P75?
thanks again.
Posted: Fri Jan 08, 2010 10:31 am
no
