RPM Idle boucing problem
Alfa
Post by Alfa »
Hi, i have a civic european model EP3(k20a) from 2005, this car has just CAI Inject and full exhaust system. (and hondata)
Everything was going fine until i had the brilliant idea to reflash it with a new map. After the reflash the car didn't start, so i went back to the internet and found a new one here at this forum.
Now everything works fine expect the idle, at the start the car does high rev's to warm the engine.
Once the engine temperature is stable, the RPM bounces between 1000 and 2000.
Any idea?
Alfa
Post by Alfa »
Im posting a datalog, please help me
Try cleaning your idle controller on the throttle body. It probably is just stuck.
Alfa
Post by Alfa »
Spunkster wrote:Try cleaning your idle controller on the throttle body. It probably is just stuck.
Thanks Spunkster i will try that, but what about the errors i get?
Circuit Malfunction? should it be just wires?
Alfa
Post by Alfa »
Hi, the problem still presists.
I've got this two errors from K-Pro:
CODE - DTC - Description
41 - P0135 - Primary Heated Oxygen Sensor (Primary H02S) (Sensor 1) Heater Circuit Malfunction
65-2 - P0141 - Secondary O2 Circuit Heater Circuit Malfunction
kb58
Post by kb58 »
The errors literally tell you want's wrong. Go check the wiring and if it looks good, replace the O2 sensor.
Mid-engine K24 turbo Locost, http://www.midlana.com
