Compatibility???
Posted: Mon Dec 21, 2009 10:43 pm
by 78civic
im about to pick up a flash pro for my 06 fg and was wondering,.....????
how tunable will flash probe for use on my set up? and has it been done before?
im using the stock 06 si (k20z3) head
and a 06 accord stock bottom end (k24a8)
im having a lil hic-up at 1500 rpm when accelerating, obviously its running too lean from the larger displacement.....
luckly im not having any piston to valve clearance problems yet. i was also wondering if im goin to if we start adjusting the vtc???
Posted: Tue Dec 22, 2009 9:28 am
by all-black
the setup should be fine you can fully tune this with flashpro. i am running a k24a4 with hc pistons and a z3 head no problems i would advise you to get larger injectors. as far as vtc i wouldnt advance it to far since you most likely didnt check that before installing.
Posted: Tue Dec 22, 2009 9:39 am
by 78civic
No, it would have been smart to clay the motor before doing this.... The smart thing you did was replace ur pistons.
I have some modified 06 accord injectors that were 270cc stock now they are supposed to be 480-490cc? I'm gonna send them to RC to have them cleaned and checked... Have you heard of that?
