RC 440cc Injectors
Posted: Mon Dec 14, 2009 7:58 am
by _Mozz_
Hi,
Might need to change my injectores soon. Was thinking of RC 440cc.
What needs to be changed on the FlashPro calibration?
Regards
Posted: Mon Dec 14, 2009 11:20 am
You need to change the injector size in the calibration window under Fuel, and then tune it properly to get the correct AF ratio.
Posted: Mon Dec 14, 2009 11:49 am
by _Mozz_
Is that it??
I was under the impression something else had to be done!?
Regards
Posted: Wed Dec 16, 2009 5:44 am
by _Mozz_
What about the Injector opening times??
Posted: Wed Dec 16, 2009 12:56 pm
If you have the injector dead time information that would also be the time to put that in.
Posted: Wed Dec 16, 2009 1:39 pm
by _Mozz_
Hi,
I was looking on your Calibrations.
Noticed that the Civic SI (witch has same injectors as me), Stock equivalent Calibration has the same Injector Opening time as the FN2 Stock equivalent Cal.
So, i see that there is a Civic SI Starting Calibration for 440cc injectors, so, could i use those Injector Opening Times on mine??
Paulo
Posted: Fri Dec 25, 2009 8:34 am
by _Mozz_
Hondata?? Any thoughts??
Posted: Fri Dec 25, 2009 10:19 am
by nunoctr
there is a MAP 440 cc injectors starting calibration for the fn2 on flash pro.
Posted: Fri Dec 25, 2009 2:51 pm
by _Mozz_
Its for the Civic Si (FG2/FA5).
And thats what i am asking, could that be used on our FN2??
Also, i would like a MAP cal.
Regards
Posted: Sat Dec 26, 2009 7:45 am
by nunoctr
it's for both cars.
Posted: Sat Dec 26, 2009 10:02 am
by _Mozz_
:D
All i need now is a IPS K2 Calibration to start playing...!!
Regards
Paulo
Posted: Sun Dec 27, 2009 7:16 am
by dinoc
Are there any MAF calibration for this 440/410 injectors ?
Posted: Wed Jan 13, 2010 10:59 pm
by mw1978
dinoc wrote:Are there any AFM calibration for this 440/410 injectors ?
NOOOOOOOO!!!! Only for MAP
