Extreme loss of performance and fuel economy
zach_04lx
Post by zach_04lx »
Hello,
Firstly, here is a summary of my car specs and such:
KManager Version: 1.3.9
Vehicle: 2004 USDM Honda Civic LX coupe with JDM K20a (ITR) swap (Y2M3 tranny) - custom CAI and exhaust
ECU: PND with K-pro
I have had this same setup for a couple years now. Last year around this time I had the same problem, but it was not this severe. When it gets cold outside, my fuel economy and performance both drop drastically. For instance, it is between approximately 0 and 5 degrees Celsius here, and the colder it gets, the worse the problem gets.
During the hot summer months (~25 - 38 Celsius), I get around 550 - 575 km to the tank (~47 litres). On my tank last week, I only got 420 km. It also seems very sluggish.
I have attached my .kal, and will go out and datalog if that will help in analysing the problem.
Thank you preemptively,
Zach
2004 USDM Civic LX coupe
JDM K20a ITR engine (Y2M3 transmission)
Custom intake / exhaust
K-pro PND ECU
kb58
Post by kb58 »
I know of OEM cars where the same thing happens. It may have nothing to do with KPro.
Mid-engine K24 turbo Locost, http://www.midlana.com
zach_04lx
Post by zach_04lx »
It just seems so odd because of how extreme it is. I could possibly see a slight drop in fuel economy, but this is insane! Is there anything for which I should look to diagnose the problem?
Thank you for your prompt reply though. :)
K-pro PND ECU
zach_04lx
Post by zach_04lx »
I went out for a typical drive today and did some datalogging (for quite some time). I have uploaded the log to my server as it kept getting an upload error here. Can anyone offer me some ideas on troubleshooting? There is obviously a problem with the AF as it is quite erratic.
Datalog (~5 degrees C outside)
K-pro PND ECU
In your datalog the short term fuel trim is maxed out (+47%). Look at the oxygen sensor first.
zach_04lx
Post by zach_04lx »
I have changed out the primary O2 and now the problems seemed to have gone away. It doesn't feel like I'm going to buck through the dashboard when I shift, and the performance is back. I haven't gone through a tank of gas to see whether or not the fuel economy is back to normal. I also haven't datalogged yet (need to borrow a friend's laptop with Windows since KManager doesn't work nicely with Linux), but it seems good.
Though the performance and such seems to be back to normal, I am now throwing two CELs. I get codes P0134 and P1166 regarding the primary O2. I have cleared them, but they come back after the car has been on for a few seconds. Any ideas?
Thank you very much for the help thus far.
--Zach
K-pro PND ECU
The Spectacle
Post by The Spectacle »
Those codes typically mean the o2 is wired in wrong. Did you install a PnP o2 or splice a non standard one into your existing wiring?
I bet if you check your datalog now, you're running in open loop which is why the car is running better.
zach_04lx
Post by zach_04lx »
It is a PnP one, and I don't know why I wouldn't have the CELs on the previous one but I do on this one. This O2 is the Denso 234-9005 which is for the RSX type-S. Is it bad to be running open loop? Sorry for the dumb questions, but this is not really my area of expertise. I will datalog sometime soon.
K-pro PND ECU
