ral24
Posts: 8 Joined: Sun Dec 06, 2009 9:03 am
Post
by ral24 » Sun Dec 06, 2009 9:20 am
Pls need help the s300 stop data logging the red light stop blinking and I can’t download or upload information I plug the usb out and in and star working for 1 to 2 minutes I did this 4 time and then the red light comes on and the green off and the stop working and the check engine come on and there is no code, when I do data log the s300 do not save the information, I am using resistor spark the ecu is a p28
ral24
Post
by ral24 » Mon Dec 07, 2009 8:23 am
Pls need help with this do I need to buy a new s300 or a new ECU thnx
Posts: 24386 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Dec 07, 2009 1:25 pm
From Help, About, what version of software are you using?
ral24
Post
by ral24 » Mon Dec 07, 2009 9:12 pm
the version is the 1.4.4
Post
by Spunkster » Tue Dec 08, 2009 11:04 am
Download the most recent version which is 1.4.4.1
Upload a fresh calibration from File, New and see if the problem goes away.
ral24
Post
by ral24 » Tue Dec 08, 2009 3:13 pm
I didi that and is not woking
newsoltsc
Posts: 98 Joined: Fri Oct 09, 2009 11:49 am
Post
by newsoltsc » Tue Dec 08, 2009 3:21 pm
Was this new or used when you bought it?
Has it worked before?
I'd pull the cover and check for any burn spots (maybe something fried)
-Jose
ral24
Post
by ral24 » Tue Dec 08, 2009 3:27 pm
is used It was out of a racing car and was working in the recing car all insaid is ok the car is workin but with that problem
Post
by Spunkster » Tue Dec 08, 2009 4:02 pm
Try it in a different vehicle and see if the problem persists.
newsoltsc
Post
by newsoltsc » Tue Dec 08, 2009 5:45 pm
ral24 wrote: is used It was out of a racing car and was working in the recing car all insaid is ok the car is workin but with that problem
What car did it come out of?
What kind of car do you have?
And what do you mean by " I am using resistor spark" ?
-Jose
ral24
Post
by ral24 » Thu Dec 10, 2009 10:26 am
I give up with the s300 I am going to buy a AEM
the ecu was out of a civic b18c1 from a friend he whent to AEM
Mi car is a civic cupe 1993 with a B20 vtec turbo
plugs are resistor
Post
by Spunkster » Thu Dec 10, 2009 10:54 am
What else has been done to the ignition system?
lowblow
Posts: 86 Joined: Thu Dec 10, 2009 2:19 pm
Post
by lowblow » Thu Dec 10, 2009 3:37 pm
How long you been runing this s300 with your motor?
Clear s300 software from your computer and reinstall s300 software see whats going on
ral24
Post
by ral24 » Sat Dec 12, 2009 4:58 am
My engine have a MSD distibutor but I test the p28 in a stock car and have the same problem, I have an oter car with the same problem, the other car is a track car, the is S300 are arrund 2 to 3 years old in my car the s300 have 2 weeks and have this problem from the fist day I test with a other PC and have the same problem , I change all the capacitor of the ecu and still do not work
