atmospheric pressure sensor
Posted: Fri Dec 04, 2009 1:48 pm
by integra579
what does "use atmospheric pressure sensor compensation" mean?
Posted: Fri Dec 04, 2009 2:16 pm
by fly_n
If u are running a TPS based fuel & ignition table tune(Alpha-N) such as when using ITBs,then u can get some relief from varying air pressures when driving at a different altitude to where you tuned the car at,if u check the "atmo pressure comp" box.
U will need to have a barometric pressure sensor onboard the ECU for it to work or i do believe some cars have the baro sensor external to the ECu,im not sure,i come from the land of eternal sea level,we dont have baro sensors down here. Its only like 2 of our tracks are 600 & 800m absl,the rest are sea level.
If your running on MAP based tables,then dont worry about that setting
