Kpro stays offline, no signal.
Prophecy1320
Post by Prophecy1320 »
Kpro stays offline
-Used a different usb cable
-Re-installed kmanager
-Re-installed usb driver
-Tried with a different laptop.
Nothing, I plug in the usb to upload a map and I get NO signal. Offline.
The green light does turn on the kpro but thats about it. I did streettune not
to long ago and had xzero problems, I have owned the kpro for 1 year already
first time this happens.
UPDATE**
I called my brother down who has almost exact setup, plugged in kpro and
works perfectly fine, Using same USB and laptop I was using before so Iam guessing my kpro is bad? both cars are RSX-S. I searched and noticed my problem has occured before to others but found no solution?
WHen you plug in the USB cable, what shows up in the Windows device manager?
Prophecy1320
nothing "unkown usb drive".
Fml
EDIT**
I came to the conclusion the problem lies somewere on the daughter board (kpro), I pulled out the kpro from my ecu and swapped it out with the daughter board from the working ecu I used for reference. I reconnected my ecu to the kmanager and it worked ecu went online, I was able to datalog upload calibration like normal. I did visually inspect the board and I didnt see any scorth marks and nothing smelled funny. Contacted Hondata already, lets see what happens.
2point0vtec
Post by 2point0vtec »
I had the same problem. My kpro would connect and when i try to upload a map it go offline and it was MY KPRO BOARD that went bad. Had to buy a new one cause it was out of warranty or what not. =(
You will need to call and obtain an RMA number.
playaz97
Post by playaz97 »
im having the same problem but i am still troubleshooting but still nothing.
presently i have reached the point where im getting unknown device in my device properties and when i manually update the drivers, im getting an error - device could not start (code 10) but the drivers are installed.
ARGGHHHHHH!! i am really fustrated because i probably used mines about 3 times (uploading) since i purchased it in August 2009! I dont want to believe that its spoilt. I have no authorised dealers in my country. I purchased this over the internet!
HELPPPP!!!!!!!!!1
b00sted_k20
Post by b00sted_k20 »
im having the same problem. bought mine new back in july 09 and tuned my car, then i go to re-tune it when it got cold and mine stays offline too. theres no instructions on how to fix it. i emailed the hondata support and got nothing. my car is now cutting out when i hit boost so im kinda effed till i get it fixed.
playaz97
Post by playaz97 »
i got mines sorted out via email from hondata, i jus had 2 install a olderversion of kmanager.
Alexx
Re: Kpro stays offline, no signal.
Post by Alexx »
@Prophecy1320: do U able to fix ur prob?
ibraMP
Post by ibraMP »
Him having the same problem!. i import the car from uk and i didnt have a hondata dealer near. I cant conect the kpro to my paltop.
Please help!!!
Regards
