Hi hondata..
i have installed a jrsc kit and 650 cc injector, kpro pra ecu and i have modified my kal in fuel trim parameters 650 cc injector!but when i upload a kal with engine on, the af ratio go too rich 10.0 and the engine go to off because they have too fuel...
How this??is possible to modify??
Upload a kal with engine On..
Honda Ep3 stock k20a2 jrsc
This is normal - the ECU goes into limp mode when uploaded. When uploading a calibration for the first time, do it with the engine off. After that, if you make a small change, you upload with the engine running as long as the engine is idling. You'll need to increase the rpm to 2000-2500 rpm as you upload so that it does not stall.
