No values displayed in sensors columns
clarkj228
Post by clarkj228 »
I just received my ECU (serial #7509) and followed the instructions for setup including ground relocation and checking for updates. My symptom is that there are no values displayed in the sensor values list with key ON/engine off or while running. The engine runs ok with several base calibrations, green light is on next to USB port, and calibrations upload ok.
Additionally, my rpm reads almost double on my factory gauge cluster than what my digital shift light reads and both run higher than set target rpm. Both are attached to connector E blue 26
-93 SI hatchback with k20a2 engine swap. Stock type s cams and factory type r (11.5:1) pistons,injen cold air intake, r crew header,02-04 speed sensor (low freq) ,310inj.
-I hope I've given enough info, just wanting to know what I should check and what base map I should begin with
V1.3.7.0 installed
-James
Are you hitting F10 to datalog?
clarkj228
Post by clarkj228 »
WORKS FINE, DIDNT KNOW YOU HAD TO HIT F10 EACH TIME. RPM OK TOO. THANKS...
