interface box randomly shutting off
pills_PMD
Post by pills_PMD »
I've got a p28/stage 4 that works flawlessly on my 94 del sol ls/vtec
my friend has a 96 hatchback that he also runs a p28/ stage 2 system on. his car will randomly shut off the interface box and stall. the light on the box will just go off with no rhyme or reason. well anyways.. i tried to plug in my system just to see if it would work properly and sure enough it didn't. any ideas as to why it would just randomly turn off? he's running an obd2 distributor that was known to be good and an obd2 to obd1 conversion harness that also worked on another friends car.
it briefly flashed a few codes in hondalogger, but none were saved and the CEL on the dash never came on.
Sounds like a wiring problem in the car that is cutting power to the ecu.
pills_PMD
Post by pills_PMD »
i agree, but what such things would cause the ECU to shut off like that?
QUICKSILVER RACING
Post by QUICKSILVER RACING »
A25, D1 and check the +5 output or ground in CN2.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
raymond
Post by raymond »
QUICKSILVER RACING wrote:A25, D1 and check the +5 output or ground in CN2.
how did you know? all your post here is just being a smart ass dude! no thanks for your help. ill listen to matt insted
QUICKSILVER RACING
Those are suggestions. A25 is the main power, D1 is the another supply, 2 pins in CN2 supply power to the interface box.
Or you can check all the wires? It's easier to check the first 4 wires.
+639178954747
pills_PMD
Post by pills_PMD »
i appreciate the response quicksilver... thanks
