Page 1 of 2
Reflash Rebate
Posted: Mon Nov 02, 2009 7:37 am
by _Mozz_
Hi,
Cant seem to be able to ask for my Rebate, as it tell me the ECU hasnt been reflashed. But it has!!
What can i do?
Regards
Posted: Mon Nov 02, 2009 11:21 am
Can you tell use the part number of the ECU and what reflash it has? You can use the 'send support information to hondata' function if this is easier.
Posted: Tue Nov 03, 2009 10:24 am
by _Mozz_
Hi,
Yesm that is what i tried to do. I use the reflash calibration that comes with FlashPro.
Dont have ECU number here, will see later.
Regards
Posted: Fri Nov 06, 2009 5:18 am
by _Mozz_
ECU Part Number:
37820-RSP-E02
Posted: Fri Nov 06, 2009 9:05 am
Sorry, I needed the ECU part number. Use the 'send support information' function.
Posted: Sun Nov 08, 2009 4:47 am
by dinoc
I have the same problem with mine.
I have FlashPro and OEM ECU reflashed with a custom MAF calibration by CPL Racing Uk, but when I tried to use your "rebate" function it tells me the same, like the ECU is not reflashed .
What can be the problem ?
Posted: Sun Nov 08, 2009 9:54 am
by _Mozz_
Hi,
I still have the same Problem.
The message that comes up is:
"There was a problem processing your rebate request. (ECU has not been Reflashed)
Any pointers??
Regards
Paulo
Posted: Mon Nov 09, 2009 10:50 am
by _Mozz_
Support information sent..
Paulo
Posted: Mon Nov 09, 2009 11:30 am
Got the support information, but can't find your ECU in our database.
Do you know when it was reflashed, and what program was used?
Posted: Mon Nov 09, 2009 11:33 am
by _Mozz_
Used the latest version, and it was on the 20th of October.
Regards
Posted: Mon Nov 09, 2009 5:43 pm
Are you confusing a 'reflash' with 'reflashed by FlashPro'? They are two different products. Since we don't offer a reflash for the E02, I think this is the case.
Posted: Tue Nov 10, 2009 7:27 am
by _Mozz_
OK,
I am using the stock ECU reflashed by Flashpro.
What do i need to do then?
Posted: Tue Nov 10, 2009 8:10 am
The rebate only applies to existings reflashes which we have sold. See
http://www.hondata.com/flashpro_civicsi.html
Posted: Tue Nov 10, 2009 9:17 am
by _Mozz_
Hi,
I Also have a Reflash ecu!! Just not using it with flashpro....!!
Do you want the number of that aswell??
Regards
Posted: Tue Nov 10, 2009 10:51 am
You must use the FlashPro with the reflashed ECU to get the rebate.
