specs for map: H22a, 680cc injectors, t3/t4 turbo, 3inch exhaust, boost control 13psi
This map was created by Brauning Motorsports, King George VA.
The map will be good enough to get your car to a good tuner... I drove the car and the map needs lot of work but will get your car up and running to a good dyno shop.
H22a turbo 13psi map
95 Accord EX; JDM - H22: ARP head studs Cometic gasket; compression dropped; Moroso Oil pan; AEM fuel rail, 680cc injctrs & pressure regulator; 255 pump; T3/T4 turbonetics kit. 5spd stage3 clutch, light flywheel. Hondata S300
