USB cable
Tsuchinoko
USB cable
Post by Tsuchinoko »
How long can be a USB cable for smanager without loosing or slowing the info?
Those who know don't tell, and those who tell don't know.
The maximum length for a USB cable is 3 metres (10 feet), but 15 fett usually works too. Using extension cables (even if less than 10 feet) often doesn't work.
OSracer
Post by OSracer »
The only way you can have an extension over the limit of the normal cable length is with a cable that has a booster or repeater built into the cable. I have a few 16 ft cables I have used for the xbox 360 and rockband with the kids. I am unsure if they will function correctly with the s300.
http://www.cablesdirect.com/usb/usbext.asp#REPEATER
I will test my USB repeater out and give results.
Also another option could be on the same page:
USB CAT5 RJ45 150ft Active Repeater
USB-C5EXT
Extends USB to a maximum of 150ft. This active repeater uses standard CAT5/5e/6 RJ45 cable for added flexibility. It activelyboosts & regenerates USB signal for maximum performance. USB 1.1 compliant. (Connectors: Type A Male/RJ45 Female to Type A Female/RJ45 Female; Colors: Metallic Gray)
OSracer
Post by OSracer »
Running through 54 ft of USB.
One standard 6ft cable
(3) 16ft Repeaters
I was able to download the current Calibration and it is online but I did not test to see if there is any delay with datalogging. If there is it would probably be in Milliseconds and I would not be able to tell.
kinetics
Post by kinetics »
Data gets lossy over that much cable.
Same reason you shouldn't run over 300ft of Cat5/5e, or any of the other recommended lengths for data cables, you end up with lossy signal and lots of noise.
I wouldn't trust that, nor would I recommend it, if you want to get clean readings/logs.
OSracer
Post by OSracer »
When I get the car fully tuned which wont be until next spring... If you could not tell the car sits very much. I will datalog with both a regular cable and the repeaters. The whole point of the repeaters is to boost the signal bidirectionally for no data loss.
