need help after upgrade to version 1.3.8.0
Posted: Wed Oct 21, 2009 9:25 am
by dcloo
here was my hondata
hondata serial no: 05863
hardware 2.16
i got ignition retard when try to pull full throttle
and its retard to -10 degree
Posted: Thu Oct 22, 2009 8:54 am
What is the exact problem you are seeing? At what time in the datalog do you see the problem?
Posted: Thu Oct 22, 2009 11:21 am
by dcloo
when the time shift to 2nd gear and press the throttle the car was just retard the ignition to -10 degree and the car not moving
and you can see from the datalog from 47-53 and 1:02- 1:07 first i think its was TPS ignition retard/ gear or temp compensation but i double check its
and everything setting was fine
Posted: Thu Oct 22, 2009 2:25 pm
Change your air temperature ignition retard 'medium to high engine load' so that there are no negative values.
