need help after upgrade to version 1.3.8.0
dcloo
Post by dcloo »
here was my hondata
hondata serial no: 05863
hardware 2.16
i got ignition retard when try to pull full throttle
and its retard to -10 degree
What is the exact problem you are seeing? At what time in the datalog do you see the problem?
dcloo
Post by dcloo »
when the time shift to 2nd gear and press the throttle the car was just retard the ignition to -10 degree and the car not moving
and you can see from the datalog from 47-53 and 1:02- 1:07 first i think its was TPS ignition retard/ gear or temp compensation but i double check its
and everything setting was fine
Change your air temperature ignition retard 'medium to high engine load' so that there are no negative values.
