Hondata S200 cables
C i v i c B 1 8 C 1
Hondata S200 cables
Post by C i v i c B 1 8 C 1 »
Hi i'm new to the forum and need some help.I just bought a used S200 but it didn't come any cables to connect to my laptop.So what kind of hondata cable do i need? and where could i get one.or could i just use any universal cable? Thanks.
It really depends on what the s200 has. What is the serial number of the s200?
C i v i c B 1 8 C 1
Spunkster wrote:It really depends on what the s200 has. What is the serial number of the s200?
i bought the s200 used.do i have to plug the ecu into the car then connect to the ecu to get ther serial number ?i'm new at this.
Last edited by C i v i c B 1 8 C 1 on Tue Oct 20, 2009 9:31 pm, edited 1 time in total.
C i v i c B 1 8 C 1
i bought a GigaWare Usb-A to serial cable from radio shack and when i go to the FTDI usb driver fix it says "could not find any ftdi devices",but the cable works it pops up in the device manager
That calbe will not work. You must purchase Romeditor 4 which comes with a special USB cable which allows it to work.
The serial number is on the bottom of the s200.
C i v i c B 1 8 C 1
Spunkster wrote:That calbe will not work. You must purchase Romeditor 4 which comes with a special USB cable which allows it to work.
my serial number is 310.782.8278 and could i just buy the usb cable alone ?
That is a phone number I need the serial number which comes after s200.
C i v i c B 1 8 C 1
Spunkster wrote:That is a phone number I need the serial number which comes after s200.
oh so the serial # must be s200-2001
it only has the boost option. If you wish to datalog or tune yourself, you should upgrade to the s300 as it will be cheaper and easier for you.
http://www.hondata.com/s300upgradeform.html
C i v i c B 1 8 C 1
so i can't use it for an all motor setup ?
You can, but it will have to be tuned by a Hondata dealer.
ZIGZAGJDM
Post by ZIGZAGJDM »
there is a cable exsactly the same as the hondata cable for only 17 dlls.
do you know if that will work?? with my s200?
DO IT RIGHT,OR DO IT TWICE!
EM1CREW
It will not work.
marka
s200 features
Post by marka »
Hi is was just wondering
My serial number is s200 - 2084
Can you tell me what feature i have installed
Thank You
