What happens when u run off the edge of the fuel & ignition tables?
Do values keep interpolating right off the edge of the map or do u get the last value seen where it ran off the map?
Just wondering as to what cranking values would occur,considering ive never seen a table start at less than 500rpm.
Also,guy that did my original cal where i bought the s300,had my vtec set to 4800rpm(with no boundary window set) & my high speed tables starting at 5000rpm,took me like 3 months to notice the discrepancy but i noticed no ill effects although considering its only a 200rpm difference,but still,anyone know what happens when u run off the map?
Obviously it reads something "off" the tables,ecu doesnt seem to go into "i dont know" mode if your off the edge.....
