ukdm ep3 turbo map
Posted: Sun Oct 11, 2009 5:59 am
by drummergsi
hello i have a 2003 civic type r turbo running a t4 turbo, kpro ecu 650cc rc injectors i need a map to drive on while i run the new pistons and bearings in can anyone help me ? thanks in advance.
Posted: Sun Oct 11, 2009 9:40 am
by cranny
there is no map youl be able to put on and just run it.
Posted: Tue Oct 13, 2009 4:03 am
by drummergsi
i need something to drive on with 650cc injectors and in the pra maps on the disc there is no maps for a turbo wat do i do ?
anything ?
Posted: Wed Nov 11, 2009 11:28 am
by drummergsi
Can anyone give me something to even get the car drove to the mapper ??.
Posted: Wed Nov 11, 2009 3:44 pm
by keto06
Can you not use the PRB maps? i
Give this one a try and see if it works.
Posted: Mon Nov 16, 2009 4:54 pm
by drummergsi
i will try it see how it goes cheers buddy.
Posted: Mon Nov 16, 2009 5:09 pm
by keto06
what you should do is copy and paste those maps into a PRA map in KPro to make sure it works.
Posted: Tue Nov 17, 2009 6:20 am
by cranny
keto i dont understand what your doing here. maybe you guys dont read well , THERE IS NO MAP YOU CAN LOAD ON AND SIMPLY DRIVE DRUMMER. pick one of the calibrations in Kmanager that closely matches you setup , set any parameters that may be different. go for a drive in closed loop , datalog it see how it runs. make adjustments.
actually list your entire setup for me pal.
Posted: Wed Nov 18, 2009 12:53 pm
by drummergsi
I understand that there is no map ya can just drive away at it will need addional attention but there is no pra maps that closely match my setup. does the prb map read the narrow band sensors? i think they use wideband. I dont know much about this. thanks in advance lads.
Posted: Wed Nov 18, 2009 4:03 pm
by keto06
Yes the PRB uses wideband, hence why i suggested copying that map into PRA tables.
And I know you understood that it was not a load and go scenario.
Copy each of the 26 tables (12+12+2) into a PRA map and do a run and post a datalog.
Posted: Thu Nov 19, 2009 12:40 pm
by drummergsi
can i open up two seprate windows at the same time or do i have to keep opening and closing the two map windows ? i am picking up as i go yous boys are good help.
Posted: Thu Nov 19, 2009 1:27 pm
by keto06
I cant figure out how to open two windows.
I just use the Reopen to click between the two since it stays in the same cam angle so I can copy and paste/
Posted: Thu Nov 19, 2009 2:44 pm
by drummergsi
done it there back and forth and changed the tables starts fine sounds good all lights out so all good so far. with the prb map in it was throwing up internal error in ecu must have been because the differences in lambda sensors. i will post back when i get a datalog sorted out, once again thanks alot.
