Burnt injector coil (twice)
darknight
Post by darknight »
Has anyone run into this issue? This is a K swap stock motor running a fine tuned base map from the software.
We have had 2 injector coils burn out. Has anyone experianced this? Or at least can anyone guess what the problem is.
locash
Post by locash »
I've never seen this before, and have probably tuned over 100 k-swapped cars.. I would take a close look at the wiring, although the coil stuff should all be in the stock RSX engine harness..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
I've seen this where the blue/white coil trigger wire was mistaken for the alternator wire. Take the coils out, plug them in, switch on the ignition, and see if any get hot - they should not.
