Feature request
Posted: Wed Oct 07, 2009 9:00 pm
by redk20simia
is there any way that you guys can add a feature that allows closed loop operation through the wideband input? I dont have a primary sensor but im running the aem wideband.
Posted: Thu Oct 08, 2009 12:47 am
by omgu8myrice
Lean protection!!!!
Posted: Thu Oct 08, 2009 8:24 am
The ECU has an integrated wideband controller and can only use the Honda o2 sensor. It would be very difficult to get it to run in closed loop using a voltage output from an aftermarket wideband controller.
Posted: Sun Oct 11, 2009 12:16 pm
by 2rotormotor
what if we wire the analog output to the primary sensor?
Posted: Sun Oct 11, 2009 3:48 pm
by firestrife
I'm no expert but I think it wouldnt read correctly due to the different voltages and interpretations by the the Aftermarket wideband and the Honda O2 wideband.
Posted: Thu Oct 15, 2009 9:23 pm
by soxfan143
The Factory Primary O2 is a current based sensor. It operates completely different. It is not a 0-5v operation. It's really hard to explain. This would take way too much effort and memory to accomplish. I would rather see them implement boost control or something. Besides, the stock wideband seems to work awesome now that they implemented the AF corrected value. No need really to interface the wideband to control anything. IMO.
Posted: Sat Oct 17, 2009 6:53 pm
by redk20simia
soxfan143 wrote:The Factory Primary O2 is a current based sensor. It operates completely different. It is not a 0-5v operation. It's really hard to explain. This would take way too much effort and memory to accomplish. I would rather see them implement boost control or something. Besides, the stock wideband seems to work awesome now that they implemented the AF corrected value. No need really to interface the wideband to control anything. IMO.
The aem wideaband had been tested to be the most accurate along with the innovate unit.
Posted: Sat Oct 17, 2009 8:00 pm
by omgu8myrice
Still waiting on lean protection...
