VTC issue on K20A2 Civic Type R Euro supercharged
JanIvar
Post by JanIvar »
Hello
I have done dyno tuning. Everything work well some few hours,
but then I got problems.
I have done this.
Low CAM
Set Vtec point high (5500RPMsuperc)
Set cam angle everywere to 0 or 10 for low and high cam.
But still I dont can lock cam angle. when I look in sensor values I
can se CAM and CAMCMD go from 0-45 cam angel degrees
when I push full throttle or accerate. There is not possible to set cam angle locked at 0 or 10 or 20 degrees.
Something wrong with VTC solenid or ECU??
Ground on motor i have done.
I use kmanager 1.3.7.0 and cal file k20a2-civictyper-jrsc-550cc.kal
JanIvar
Post by JanIvar »
Can you please delete topic, I found out the problems.
My fault. Im sorry for the issue.
