OEM Mapsensor and real pressure
Posted: Sat Oct 03, 2009 3:12 am
by ralf1
Hi
I detected following.
I drive the car with full throttle. I detected that the datalogging from the k pro shows a maximum boost of 10.2 psi.
concurrently i test the boost with a extern calibrated boost gauge.
at the same time the gauge shows 12.6 psi.
why the difference?
regards
Posted: Sun Oct 04, 2009 1:09 pm
by ralf1
no one have a idea??!!
Posted: Mon Oct 05, 2009 11:11 am
You are at the limit of the stock map sensor, once it maxes out it cannot read any higher. It is time to upgrade to a 4 bar Hondata map sensor.
Posted: Mon Oct 05, 2009 2:26 pm
by ralf1
so the OEM map sensor is only a 10psi sensor. i doesnt know this.
the map sensor until year 2000 is a 1.75 bar map sensor. so read to 0,75 bar boost . 0.75 bar is 10.7psi.
so the EP3 map sensor is only 1.7bar or 10psi map sensor. ok, this illustrate it.
Thanks for the information.
regards
Ralf
