Help! car dies on same hill in 3rd (kal & datalog inside
Posted: Fri Oct 02, 2009 3:58 pm
by 6spd_ek
I could use some help here. My car dies the same time after rounding a right hand turn & going up a hill. I live on the hill so its tough to avoid
I see "injector ms" & "injector duty" drop to 0%!!!! (when this occurs @ 5:11) EDIT: the car has always had a full tank of gas
my guess is it may not be the tune but the car itself. its a k24a2 tsx with ITR tranny & limited slip in a '02 ep3
any tips? fyi I downshift to 2nd & the car pics back up in this case the roads were wet & I spun them a 'lil :oops:
Posted: Fri Oct 02, 2009 4:07 pm
You need to tell us exactly what time stamp this occurs.
Posted: Fri Oct 02, 2009 4:23 pm
by 6spd_ek
sorry I guess I wasn't clear starts @ 5:11 ends near 5:12.5
I think it this case I should start by checking for loose wires & checking fuel lines (any tips appreciated). but it cant hurt to have someone look at the datalog. The car's power stumbles hard at 5:11 at 5:12.5 I start my downshift to 2nd & then car/power picks back up .
Posted: Fri Oct 02, 2009 4:39 pm
Try disabling lean protection
Posted: Fri Oct 02, 2009 4:56 pm
by 6spd_ek
will try & I'll datalog... give me a lil bit its pooring rain out right now
thank you
I will cut the datalogging time-frame down too.
Posted: Fri Oct 02, 2009 6:09 pm
by 6spd_ek
with lean protection off my motor didn't die out this time. any clue why or what I can change? dont I want lean protection on?
thanks again... attached is new datalog with lean protection off. the same hill is at 1:03
also is the vtc sweep common at 0:59 (command goes to 45vtc - remember I have a stock tsx cam gear limits to 25)
Posted: Fri Oct 02, 2009 6:52 pm
by cranny
where are you located? who tuned the car? car needs tuning.
Posted: Fri Oct 02, 2009 7:48 pm
by 6spd_ek
cranny wrote:where are you located? who tuned the car? car needs tuning.
i am in upstate NY... The car was dyno tuned sometime ago & then the o2 crapped out. i just replaced it with an OEM honda one (which was in a PRB box), after replacing it I had the car street tuned. also the muffler is starting to fall apart internally & may choke the car off a little bit
whats wrong with the tune?
why did vtc command spike to 45 when the highest it is on any map is 25?
at 1:02.45 why is all the timing pulled to 3*?
I understand my 0 & 10 degree decel timing maps should be a little close but the lowest value is 27*
Posted: Sat Oct 03, 2009 8:14 pm
by 6spd_ek
started over with a new basemap (using hondata's 04-05 tsx stock .kal) & adjusted a/f. so far so good. car runs much smoother
I hope to dyno on tuesday but currently knock is disabled. I have a new oem PRB (k20a2) knock sensor but I am not sure if I can use it on a TSX motor running what I believe to be a k20a3 (ep3) engine harness :oops:
