woundering about the BASE MAPS
Posted: Wed Sep 30, 2009 2:08 pm
by eg6-k20a
what`s the difference in the K20A2 base map to a K20A base map, is it just in the VTEC column? or is there any other settings thats special from one another?
thanks in advance
Posted: Wed Sep 30, 2009 2:45 pm
The engiens have different pistons, cams, intake manifold and have different compression ratios.
Posted: Wed Sep 30, 2009 3:05 pm
by eg6-k20a
so if i was to load a base k20a2 map on my k20a engine would it be ok to tune it from there? like i know the internals are different but the calibration wise for it to run properly is there differences. thank you
Posted: Wed Sep 30, 2009 3:31 pm
It is completely up to you what base map you use
It is best to use one that is closest to your setup.
