Hi all, my name is Ben and i'm from Middlesbrough in the UK.
I have recently fitted a UKDM k20a2 into a 98 spec JDM ITR.
I am using a prc k-pro, RBC intake, DTR/SSR header, IPS K2 cams, crower springs, Ti retainers, lightened flywheel. At the moment i have a temporary warm air intake and am using the stock dc2r exhaust.
Here is the a copy of the Map i have chosen as the basemap as it is the one that most closely resembles my setup and my first datalog. (while out i noticed my vss wasnt reading so if thats how you tell what gear i was in then the first pull i did was in fourth, then i turned around, did a bit of a third gear pull, slowed a bit and did a bit of a fourth gear pull). and also a copy of my first datalog
ok i wrote the above, attached my kal ok but get an error when trying to attach my datalog? any ideas anyone?
Thanks in advance for any help.
Cheers, Ben
please help with my first datalog
try again with a smaller file.
one of them is a fourth gear pull, and the other my route back home uphill at part throttle.
i have a big issue with knock i think
also i ticked the box for permanent vss signal since i posted the cal but not sure if i uploaded the change to the ecu or not :oops:
thanks for the help
thanks for the help
