JDM K20A FULL-RACE TWINSCROLL GT35R KIT SETUP
hi, i need a map for this setup k20a with a full-race Twinscroll GT35R turbo kit, walbro 255 fuel pump, kpro of course, 1000cc injector dynamics, dual 44mm tial wastegate, 70mm exhaust, 3 inch exhaust, no cat. any help would be appreciated, and thank you for your time.
heres the map that runs my car , you can try it and tune from it if you like. post up a datalog and ill give you a hand tuning it. ill set it up for your injectors and engine.
answer my questions first.
what fuel do you use?
all stock engine?
stock map sensor?
whats your goal?
k24bottom , 87.5mm-9:1 CP pistons-IB H beam rods
k20a2 head and intake manny , all stock
peakboost sidewinder GT35R single scroll , 44mm gate
750cc injectors
255 intank and fuel return conversion
70mm exhaust , 3" exhaust , no cat
i put down 340 whp/265 ft/lbs at 8psi.
all stock engine?
stock map sensor?
whats your goal?
750cc injectors
Gonna be using 94 octane, it's a bone stock R, stock map sensor for now, but will get hondata 4 bar map sensor, my goal is to be around 500 whp. I just want to run this setup for now and build a k24 on the side and drop it in later on. Both of my wastegate springs are 0.5 bar ( 7.25 psi ). So wats the lowest psi I can run? And wats the highest psi it can run? Also wats a good soleniod that I should run? Thanks cranny
hey cranny
yo, i started it and i datalog the curtisboost.kal map
