My FlashPro is not reading the correct Air Fuel Ratio during WOT.
It is reading 13.97+ during WOT.
This includes the "Corrected" as well as normal AFR readings. they two lines when on the graph do not deviate like it has been stated they would read differently.
I know these AFRs are wrong because i have an AEM UEGO Wideband that is reading 11-12s during WOT.
I have even tried adding fuel to the entire table, the datalog shows 13.97+ same A/FR during WOT, and AEM Wideband shows 10.0, meaning AEM wideband is reading the extra fuel.
I have tried loading and reloading the CAL, I have unlocked the FP from the car, and then locked it and reloaded the CAL.
I have bought and replaced my Fuel Pressure Regulator.
I have inspected the Primary O2 sensor.
also i read somewhere that there is a way to wire in your guages to the flashpro. how do you do that?
